I installed 2025 and for some reason the Date and Time sliders on the Shadow Settings dialog box are not working. Does anyone know how to fix this?
Are you using an environment in the model? If so, Date and Time will be disabled and the sun’s angle will be set with the sliders in the Environment panel.
If you untick Set Sun Location in Environments then Date and Time in the Shadows panel should work.
Perfect…thank you!
