Hi all, hoping someone can help with a Send to Layout issue I’m having on Mac (Tahoe 26.5, SketchUp & Layout version 26.2.242).
When I use File > Send to Layout, Layout opens correctly and my template loads with all its fields and borders. There is a viewport box on the template with blue selection handles when clicked, but the SketchUp Model panel shows “No model selected” — meaning the viewport is empty and not linked to my SKP file.
I have confirmed the following:
Scenes exist in my SketchUp file and are saved with all properties
Both SketchUp and Layout are installed together in the same SketchUp 2026 folder in Applications
There are no .plo files in ~/Library/Application Support/SketchUp 2026/LayOut/
Layout itself works fine — if I open Layout separately and use File > Insert, the model appears correctly
The issue happens across multiple different SKP files
So the handoff from SketchUp to Layout is working (Layout opens, template loads, viewport box is there) but the model is not being placed into the viewport automatically as it should be.
Has anyone experienced this on v26.2 Mac, and is there a fix beyond using File > Insert as a workaround?
Thanks, Bob
