Select active clipping box disappeared from shortcuts
After updating from 2026 to 2026.2 the select active clipping box shortcut broke
Here are picture from 2025 sketchup and 2026. please help, the 2025 sketchup is much buggier on my computer, and I use that shortcut all the time
Hi,
Thank you for reporting this issue. So that we can quickly check where is the error, could you tell me which version of Scan Essentials you are using ? And the Sketchup detailed version as well.
Best,
YS
Scan Essentials V. 1.2025.0923
Sketchup V. 26.2.243
Thanks
Hi,
Can you try to update your version of Scan Essentials ? (Version 1.2026.0421 on the Extension Warehouse). It should contain the shortcut again,
Best,
YS
