Issue with Edit-Item-Instances-Select Active v2026.2.243
Just updated to this minor version, and now after using my short cut(Alt + a) for Edit/Item/Instances/Select Active .. and then try to exlplode using my shortcut(Shift + e), it doesn’t work. In order for me to get it to explode after the instances are selected, i click orbit button (while selected), and then try to explode again and it works.
If i just drag select, or individually click instances, then try to explode, it works first time.
Anyone else having this issue?
You might check your short cut menu to see if it somehow got changed or corrupted in the update.
I have checked that, i removed my shortcuts, and added different ones.. Issue still persists.
From discussions over a couple of days I understand that the latest version has issues with all or some shortcuts using the ALT key.
Interesting, thanks for that tip. Yeah if i switch the select shortcut from Alt to shift and try to explode, its working as expected now. thanks. Hope this gets fixed soon.
