I’m trying to use Sefaira to run a daylighting model and keep getting this error when I try to start the plugin:
Uncaught Error: Load timeout for modules:
common/views/visualizedaylighting,pub/daylightMetrics
http://requirejs.org/docs/errors.html#timeout
I think the problem is that my model is too complex for my PC to successfully run the plugin. I’ve tried to simplify the model but I’m still having the same issue. If anyone has some tips for solving this kind of problem some advice would be greatly appreciated.
Thank you
I forgot to mention my model is a .ifc import. I’m curious if that has anything to do with the error.
@cddamico I doubt that this error is showing up because of an .ifc import. However, one thing that I would do first is draw a 20’ by 20’ by 10’ box in SketchUp and try running a Sefaira analysis. Check to see if that runs or not?
If it runs fine, then we know that the error has got to do with something else and not your model in particular. And if the analysis runs fine then there is something in your .ifc import model that is causing the error.
I would recommend that you always check against the Sefaira modeling guidelines listed here and see if the .ifc import meets the requirements listed in the modeling guidelines.
