I’m having an issue in Sketchup with sectioning as it will not show the interior space. Im using online-version and tried the cut at different angle and interior shows (!). How can this be solved in online version as I have tried the display-options online to solve the issue. I have started the section cut several times to re-try without solving the problem.
Greatful for any swift fix or advice for this issue!
I am assuming there is no interior space - unless you intend for the walls to be paper thin.
You can turn off the ‘fill’ and it will let you see inside. But if you intend for this to be somewhat realistic you’ll need to model the walls with thickness.
