Section Cut Face Crashing
TIGs section cut face plugin crashing over and over and over.
I’ve turned off just about all my extensions that I had loaded, doesn’t seem to have helped.
Sometimes if I am in a basic style (no profiles, no background, etc.) it works just fine, but most times I crash.
Crash Report #7933
Was the last one, also searchable by my login email.
Crash Report #7935
Crash Report #7936
OK - I think I have isolated the issue, am testing now.
If I run the plugin to create a new scene from a scene that uses a style where ‘Section Planes’ has not been updated or refreshed - SU crashes.
Done this twice now in a row. Will test more.
If I run the plugin in a scene with a style that I have not altered (like turned the section planes on so I can see them, to create the new cut) - then it works consistently.
OK - This appears to be the case - if any change is made to the style of the current scene (like turn section planes on or off) - if you don’t refresh the style when SectionCutFace tries to make a new scene it crashes.
I have tested this by altering edges, not refreshing and getting a crash, as well as only toggling the Section Plane on and off (for visibility) - and it crashes if I do not update the style before running the plugin.
Can we keep the discussions in the tool’s thread at SketchUcation.com
[Plugin] SectionCutFace • sketchUcation • 1
Having dual posts is just confusing…
But I’d be pleased to hear any comments that the SketchUp team have on the submitted BugSplats…
Sure…
