hi, ive sent my sketch up plan to layout but only one scene comes accross…
in sketch model i cant open the scenes tab??
any advice plese xx x
With ‘Sent to LayOut’, you get one View(port) in LayOut, you can then copy and paste that Viewport and set them to other scenes. If you want , you can use an extension in SketchUp to produce pages with a Viewport for each scene:
https://extensions.sketchup.com/extension/632e5f6b-b768-43ce-9694-afe24ad15459/create-lay-out-file
best thing to do right now is to learn some basics:
https://learn.sketchup.com/track/layout-essentials
It will save you a bunch of time and frustration.
You could have one or two things going on here.
After sending to Layout, there are a number of things you may have to do. If you want different scenes from the one imported, copy/move the viewport and then select a different SU scene from within the Sketchup Model dialog box:
It’s not obvious what you mean. Have you double clicked inside the viewport? If you do that, you break the link with the SU scene. In general you shouldn’t ever do it (looks like you can’t in SU 2020).
Mike huge thanks for link and recommendations. really appreciate it as i’m a beginner and still learning. may i ask you some questions in case i would have any later? thanks for everything! https://suppsforlife.to/primobolan-an-extremely-helpful-steroid/
You better start a new topic if you run into something. I am always asleep, so here in the public forum is probably the best place. There is always someone awake ![]()
