Since I update to the SketchUp Studio subscription, the extension Trimble Scan Essentials give me trouble in Layout. When I open a LO project, I get a small window saying: “Loading Point Cloud File… (Not…” and LO becomes unresponsive and I need to crash it. I then have to go back to the model, re-activate the extension (if it was not active), then unlink a point cloud, even if I don’t have a point cloud link to the model.
So I understand I need to unlink the point cloud in SU before I go to LO… but it means I need to do it to EVERY model I open in LO… That’s absolutely insane when you think about the number of files I open every day. I’m gonna have to unlink thousand and thousand of models every year! That doesn’t make any sense!!! Is there any way I can simply say to LO to NOT LOAD POINT CLOUD ever? In other words, turning off the extension for Layout? Thanks for your help.
Development: I’ve been opening a few projects in LO to test the problem, and some of my models are linked to a point cloud (even if for me there are not) and some are not and open right away! Weird!!! I’m gonna defenatly keep testing things out.
I have begun to understand how the crash occurs. (not responding… forever): When I open a LO file that’s associate with an skp file with a point cloud associate with it, but the point cloud file is not foundable. (File has been moved or delete)
Here’s the series of events that cause my problem:
A year ago, I was using the trial of Trimble Scan Essentials, before it was part of the SU studio bundle. During that period, I have created my annual template with a cloud file associate with it. (without noticing it) During the last year, most of my file, created from that template was associate to a point cloud but there was no way for me to see or control it as the Trimble Scan Essentials was not installed anymore. The trial was expired. (And the extension was more than 500$ at that time)
So when I subscribe to SU studio (with the extension included), ALL my files created during the year needed to be de-associated (in SU) from the unexisting cloud file before the attempt to open it in LO. If I don’t de-associate it in SU, LO will try to find it in a forever loop of not responsiveness.
What would be a great fix is that LO gives us the possibility of de-associate the cloud file OR simply ignore it.
I am having this exact problem. I need to work on a Layout File referencing a Sketchup file that has only an Undet point Cloud associated with it, but Layout seems to be looking for the scan Essentials point cloud. Is there a fix for this issue? I have de-activated scan essentials as I no longer use it, Do I need to re-install scan essentials and disassociate the file from the cloud?
Uninstall Scan Essentials for LayOut manually:
- For SketchUp 2022, go to C:\Program Files\SketchUp\SketchUp 2022\LayOut\Extensions
- Delete ScanEssentials.loext and the ScanEss folder
When you say the issue is normally fixed, does that mean there should be some kind of control for point cloud in LayOut now, or when a model is unassociated with a point cloud it shouldn’t come through?
Dissociated point cloud from model, still showing up in LO. Is the only fix to remove scan essentials for LO?
Copy. I will definitely continue to use the point cloud in SU. I wasn’t having the crashing issues that others were, just no way to turn off point cloud in LO. Could be nice to have, but until there is some measure of control in LO, just deleting the plugin worked like a charm.
Hi Jacques
I have a similar problem and I see that other users have also had something similar, (will there be soon a way to unlink a point cloud directly from Layout?)
My problem is that I generated a template based on a file that handled a point cloud and now when I open that template the program always looks for the point cloud and also the Loadin Point Cloud window does not disappear. Being a template, how do I unlink the point cloud if the template is not linked to any SKP project (that’s why I think there should be native point cloud control from layout)?
I’ve been having issue with exporting a layout file that includes a Trimble scan essential model. I am able to see the scanned model in my layout viewport but when I export that to a pdf/jpg/png file I can’t see the scanned model. Can you please assist me with this issue.
We indeed have 2D images export issues in the current released version of Scan Essentials. Those issues have been adressed in the current beta test version of SE that you can access in our beta testing labs :
If you are willing to go throught that beta testing, please read the notes carrefully as we, unfortunately, still have minor issues with Scan Essentials for LayOut.
