Hi Everyone, I hope you all had a good Xmas.
I’m having an issue with the scale when exporting the drawings in dwg. The drawings are new and are in a plan 2d mm template.
When I export them and go to options the scale tick button is greyed out. When the Structual engineer opens the drawing in CAD and checks the dimensions they are out by 10%.
Any help would be appreciated.
Kind regards
John
DaveR
December 28, 2021, 1:09pm
2
Do you have the camera set to Parallel Projection? That would be a must for setting the scale.
Sharing the .skp file with us would help us help you.
Hi Dave,
Thanks for the speedy reply, I’ll have a look and check the perspective.
How can I share the drawing?
DaveR
December 28, 2021, 1:14pm
4
Drag and drop the .skp file into a reply here. If the file is too large to upload directly upload it to DropBox and share the link.
Hi Dave,
Thanks, I’ll be on my computer later so I will upload it then.
Thanks you.
Hi Dave, This is a test one I sent the SE to check the dims against. I was in perspective so maybe that was the problem.
test.skp (71.7 KB)
Dave,
This is the one I’ve made myself it was in parallel. The dims where correct on one axes but out on the other!!
Ivanhay - Floor plan.skp (2.5 MB)
DaveR
December 29, 2021, 6:15pm
8
That’s the common reason for it.
DaveR
December 29, 2021, 6:17pm
9
Notice the word ‘Top’ is missing from the upper left corner of the viewport. In addition to Parallel Projection you need the standard Top view.
After selecting the standard Top view and updating the scene…
Ivanhay - Floor plan.skp (948.8 KB)
By the way, it would be a good idea to ensure proper tag usage. All edges and faces untagged.
And purge unused stuff once in awhile.Note the file size difference between what you uploaded and the purged version I uploaded.
Looking at the model more: I’m curious about why you’ve only done 2D drawing.
txxt168
February 7, 2024, 6:51pm
10
Thanks for the sharing, I hit the same problem, it is fixed immediately after changing camera view from perspective to parallel.
