SKP to DWG conversion off by 2.4 inches
Hi,
Every time I export my skp 2D layout plan file into a dwg the walls and other measurements are off.
For example, in SketchUp are my walls are 4 inches thick but when I export into AutoCAD they’re 4.2 inches. Does anyone know how to fix that? It throws off my whole plan.
Other walls are offset more by 2.4 inches than they should be.
Thank you
Share your .skp file so we can see what you are working with. My first guess is that you forgot to set the Camera to Parallel Projection and the standard Top view before exporting but it could be something else, too.
Thank you! That was it!!!
I knew it was something simple but Google was no help!
