Scale Dynamic Components
Hey guys.!
This is my first DC, and its made with a purpose, after multiple tries and about 3 models attempt, I’ve come to the conclusion that I don’t understand what the heck is going on - my model can’t be scaled (at least not with the native tool, only with Fredo), there is no error and the math is very good.
And also, i don’t have access to the Component Options panel (only if there is another premade DC present in the model), that’s why i put a simple shelf in the model…!
So please help me understand, if any of you have the time and the knowledge.
Thank you.!
Usa cu lufturi.skp (227.7 KB)
A usa.skp (279.9 KB)
Well you choose a good one to start with, mainly the name, DCs have an issue with “u”
I separated the objects, just when you come to saving the component, avoid starting the file with “u”
To scale an item, the size attributes must be clear of formula, or use the CURRENT method in the formula.
I made the board to size by the edge strips, then the overall scaling remains constant
Thank you very much, as i said I’m new with DC…!
This bug is only for “u”, or it’s also thru for “U”.!?
