Saving Scenes
I’m setting scenes up in my sketchUp model for layout, and every time I change a scene, Like hide something or add a section plain, it does it to all my scenes. I’m only updating the single scene after doing the work.
This never happen before, I use layout often
Share the files so we can see how you have things set up.
Dave Mills.skp (2.3 MB)
You’ve chosen not to save properties for Hidden Objects, Active Section Planes, and other important properties.
So whatever changes you make to those kinds of things will show in all of your scenes. If you had been saving those properties with your scenes things would work as you expect and your updates to a single scene would only be reflected in that scene.
By the way, remember to stay on top of keeping your model clean. All geometry untagged and purge unused stuff.
Screenshot - 1_12_2024 , 1_55_32 PM
Screenshot - 1_12_2024 , 1_55_53 PM
I would also suggest using tags to control visibility of objects in the scenes instead of using Hide.
Thanks I’ll give it a try
That was it, checked all the properties on and it worked.
I don’t remember having to do this in the past but I will for now on
By default all of those properties are normally checked to be saved with the scenes when you create them. I guess you must have unchecked those boxes at some point.
It depends on the template used. Some of the default templates have several of the boxes unchecked, for some obscure reason.
