When a select a face, or just pass with a tools, there are no blue dots to show the selected/active face.
I searched all the net without luck, I tried to find some solution to drivers. Nothing.
So, I thought : could I change the way S2017 show highlighted/selected face → but I found nothing.
Without blue dots, I can work, but my young students have difficulties, and first the ones learning to use Sketchup.
Please could you help me to find a solution or workaround ?
Thanks in advance.
Kind regards to all the community,
I already upgraded drivers.
I’ve Windows 10.
Is there a way to ask S2017 to change selecting faces from blue dots to full color ?
I’m stuck on this, and this kind of workaround would help a lot…
It must be for the Intel…
So I thought : if I can change dots for a full color (example : change blue dots covered selected face for a full blue colored selected face), it could solve this.
I already found the “Choose Color” panel you sent me, but it just change the dots color…
If I just make a simple cube with a rectangle and push-pull, the face over which I move the mouse cursor remain “unselected” : no blue dots. Impossible to see that it’s selected. For my young students it’s a problem.
It’s a problem too when making complex multiple faces selection…
What screen dpi do you have on your displays? There have been some complaints that the “stipple” pattern of dots is hard to see on 4k and 5k monitors. You can change the color of the dots, as DaveR pointed out, and a garish color may make them easier to see. But as of SU 2017 you can’t change the pattern.
Thanks,
I tried to change graphic drivers… Maybe Timble should have preserved the software graphic option. Sketchup is widely used in public school were we have no money to buy new computers nor pro software…
Kind regards,
Vincent
Hello,
did you solve the issue? I have the same issue with SU 2016 and NOT with SU 2019 (installed on the same PC). So I do not think it is a graphic card problem
regards
