Bee Hive Super (1).skp (405.9 KB)
Here’s the honey super queen excluder and spacers for the other bee hive models.
The scenes explain what a queen excluder does.https://forums.sketchup.com/t/bee-hive-deep-box-brood-frames-spacer-smoker/221218https://forums.sketchup.com/t/beehive-base-with-beetle-trap/220420. I just edited, changed category to “Gallery” and added links to other beehive models I did.
hey, small off topic tip :
instead of multiplying thread for each project, you could create one signle thread in the #sketchup:gallery section. that way, anytime you update your model, or create a new one, even if it’s not related at all, it’ll be there, in you personal “blog” of sorts. As you can see, there are several of those, and it’s always cool to be able to find all the work someone dit in one place !
Then, just add a screenshot/export or two whenever you post, so people can check without exploring the skp file, and you’ll be set up.
Actually, I’m pretty sure I have the powa to take your previous thread (beehive and smoker), edit the name so it’ll reflect it’s your gallery, and move it to the proper section
Thanks, ateliernab, I’ll start posting in the gallery category instead of corner bar.
The beehive base screen is a different size than the queen excluder screen. The screen on top of the base keeps all bees out, but the queen excluder allows the worker/nurse bees through. So the spacing is different.
