Any bee keeper around? I don’t have bees yet, but I’m preparing some parts already. I’ve designed a hive stand but I’m not sure whether I have overlooked important characteristics. Any ideas?
Awesome! Maybe ant-proofing? From what I’ve read online, it’s something like putting oil (or tanglefoot) in a can around each leg to make an insect barrier.
Another version following the example of this video, no big screws for the hight adjustment needed and therefore maybe a bit cheaper than the first version (?) , but less possible height variation…
Very nice. Would the frame sit on the legs using only friction or would you somehow attach the legs to the frame once it is leveled? I would expect that once it is leveled, no further adjustment would be needed unless it gets moved.
Looks like it works very well. I don’t know that I’d keep bees but I’ll remember that method of setting up a frame to be level on an uneven surface. In fact it gives me an idea for a new thing my son and I are designing for his scout troop.
I have bees and made a basic stand which worked well until the ground softened and the legs started to dig into the ground and cause stress on the leg to frame joint, a brace has now been added without fixings to the stand to stop this, there are hives already on the stand so its a bit tricky to work with.
My recommendation if the stand is going straight onto the ground is to have nice wide feet
PS: the hive stand needs to be slightly lower at the front so rain doesnt wash into the hives
Above is the stand I made and as I said, although it seemed nice and strong I didn’t allow for changes in the ground surface, it would have been fine sitting on a concrete slab
This stand was brought here from the beekeeper himself, all of his stands are just like this one
so Im sure your build will be trouble free
