Hi!
I’m struggling with the creation of a dynamic component. I work as a general contractor and I want to build a library of Siding/Cladding profiles with full geometry. I began with a few simpler profiles and was impressed with the ease of use of the dynamic components. Now I’ve ran into a siding profile that has a random pattern of three different pieces.
At first i thought i could use the rand function to easily pick between the three but my knowledge base and coding experience is not nearly deep enough to work out how to create an actually usable component.
Here’s the simple geometry.
I tried using an AI agent to help me work out the kinks but it didn’t yield any usable results.
The way I’m using these profiles is, creating the wall shape with any rough openings (windows, doors, etc.) and then using the solid tools to cut the siding component to size and cut the holes for the openings. Is there an easier solution than a dynamic component that im not seeing? Or is there any advice thats applicable for getting the dynamic component to work?
Thanks a bunch for taking the time!
