Repeating pattern along a shoe contour
Hello all. I am tryig out how to make a repeating pattern in sketchup to follow the contour of a shoe sole. I am testing out some new TPU filament and want to practice some non-common sketchup stuff :slight_smile:
file is attached. The pattern can be any type of pattern, rectangular or wavy.
thanks for any help.
shoe.skp (4.7 MB)
Like this maybe?
I used Path Copy with this little component.
Screenshot - 12_10_2023 , 3_47_12 PM
yes, and i should have been more clear. the top section with the 5mm offset, the inside needs to have some tread.
is path copy a extension?
but yes, i need to make tread on the bottom surface of the shoe (which is the top section in sketchup)
thanks
Yes it is. You could try it on the top surface.
ok, i will try that. i have one idea i am toying with first. thanks again
ok, we got it to work :slight_smile:
2 different methods.
