Repeating Bead Pattern
i want to repeat a pattern across a line and radius any suggestions or info?
Show an image of what you are trying to do.
sketchup Question.pdf (53.7 KB)
I’m not sure how to repeat this pattern across without needing to do each one individual and also so that it can repeat across the radius, thank you for your help
Since you have a SketchUp model started already, download it to your computer and drag it into a reply here.
If you made a component of the element, you can use Move/Copy to make a linear array. It the curve at the end is an arc, you can create a radial array with Move/Rotate. See the Help files. Especially this:
https://help.sketchup.com/en/sketchup/copying-what-youve-already-drawn
