Hi. How can I rename all the textures on my model? (ex. image_1; image_2…) I did that with a script if I remember well… But I don’t remember that. Someone knows the solution? Thanks!
First collect all of the models materials:
mats=Sketchup.active_model.materials
Now step through and rename them thus:
rename="image_001"
mats.each{|mat| mat.name=rename; rename.next! }
However, if you mean the actual image files associated with a texture which is attached to a material, then it’s more convoluted, you need to filter the materials for those with textures, then save the texture file renamed [JPG or PNG] to some folder [perhaps in TEMP or with the model ?], and then immediately reassign that renamed file with the texture…
dir=Sketchup.temp_dir # or perhaps =Sketchup.active_model.path.dirname
rename="image_001"
Sketchup.active_model.materials.find_all{|m| m.texture }.each{|material|
extname=File.extname(material.texture.filename)
# keep file type, or perhaps =".png"
puts basename=rename+extname
rename.next! # increment rename by one digit
filename=File.join(dir, basename)
material.texture.write(filename)
material.texture=filename
puts
This sorts the model’s textured materials files in the order they were added to the model.
Thank a lot. I meant the first option
Thanks for the tips TIG !
TIG thanks a alot for this tip. But it is erasing the materials UVs. So is it possible to keep the same UV data and collect the textures with new name in a folder?
