Realigning axes to vertical
A simple question. In the example I have changed Axes to allow modeling different surfaces. I now want to realign the Axes so the Blue axes is vertical and the red and green are on the flat. Just can’t remember how to accomplish. Thanks.
Polyethylene Tool Foam Sheet v3.skp (233.9 KB)
Right click on an axis line and choose Reset.
axis
Good morning Dave. what I want to do is to move the blue axis to vertical so the “wood” surface is vertical and the red and green axes are “flat”.
Resetting the axes will make the blue axis vertical with the red and green being horizontal. If you want to orient the “wood surface” to vertical you’ll need to use the Rotate tool to rotate the geometry. Resetting the axis alignment does nothing to the geometry.
Thanks, the reset did it. Making a bumper for the rear drop down platform on my boat
