Push Pull wont cut
Hello,
I’m having an issue where the push pull function won’t cut an object. The behavior seems to be random. I have attached a video of what I am talking about. I have ruled out that this issue is related to faces not being parallel to each other.
In my video, you will see that push pull cut on the first object properly but it did not work on the second object, it leaves the face remaining. The second object was a copy of the first.
Has anyone else experienced this random behavior?
Can you post the model (skp file)?
This would help in identifying the problem.
Indeed, that’s usually the reason and it’s not an issue
I have ruled this out as an issue.
Here is a link to the sketchup file.
I have been helping Support to look at your file, on my M3 Mac, in case it mattered what computer you’re trying. With your later model there is no problem. Support are going to be replying to you soon with a couple of suggestions/requests.
This topic was automatically closed after 186 days. New replies are no longer allowed.
