Push pull on stacked objects
Hi,
I am very new.
I have been experimenting with sketchup and tried drawing lots of things and did the tutorials and so on.
So, if I was to draw a lego brick, for example - a cube with four spuds on the top, when I use the push pull tool from the base, it doesn’t push pull through the spuds - only the cube. I tried ‘off setting’ the wall thickness but the same result. Interestingly, if I just hide the base I get close to what I am after.
I read some of the previous posts about Fredo’s push pull but I can’t see it. Is it an extra thing that has to be downloaded?
No big thing, I am just learning.
Thanks
Ciaran
Fredo’s plugins/tools are great. However, I would recommend to wait with using any plugins and try to learn the basics of SketchUp first. You’ll definitively benefit from learning SketchUp’s native tools, no matter what.
The Push/Pull tool (P/P tool) can be used with [Ctrl] to toggle the +sign at its cursor. + means leaving the pulled face behind and dragging a copy of the face passed other geometry. Maybe this was the issue in your case.
Follow along these videos, Machine parts, Lego,Millennium Falcon.
Also go to The learning Center. All by the Sketch up people.
Thanks for your reply.
No, not really. If I was to Draw a cube with another cube on top of the first, for example, and then if I was to right-click and ‘hide’ the base, I get a hollow form rather like a vacuum form.
I want to replicate that, only giving a thin wall thickness.
I want the final outcome to look like a vacuum form and, while hiding the base does seem to replicate what I want, perhaps there is another better way.
Thanks for your help.
Ciaran
HI,
thanks for the reply.
I will watch these just now.
Ciaran
