Hello, I"m trying to make an A Frame birdhouse. It has a porch on the front. Each end of the porch is flush with the angled A frame birdhouse. I used line tool to draw the porch on front of birdhouse and push/pull it out. Then used line tool to draw (on the end of the porch ) the area of the porch that need cut away. But push/pull works perpendicular to the surface I"ve drawn on, which is angled to match the sides of the A frame birdhouse. How use push/pull to eliminate the unwanted portions of the porch? Or what better way to tackle this? thanks, Mike
A Frame Chalet.skp (440.6 KB)
Here’s a web version, since you say you are using SU for Schools.
Ugh. I’d forgot that. Thank you. Mike
