I have a piece that I have drawn out Rudder pivot calipered.skp (1.3 MB)
Now in one end I need to cut a 5mm groove out on the Z axis. however the groove is at an angle to the to the Z axis along the x axis.
I tried the Push pull tool but it pushes along a straight line and not the angle that I need. Is there any way to change the angle on the push pull or another tool I should be using?
I didn’t understand what you mean exactly but here is a plugin that allows you to push/pull curved surfaces with various options: JointPushPull Interactive.
Also your model seems a bit ‘messy’, so i advice you to check these plugins to ‘clean’ it: CleanUp³ and Solid Inspector².
