Ok, so i have this part, i have attached it, the video shows what i am trying to push pull. i need it to be lowered by 1.75 inches in the blue direction. I am having troubles lowering it. i have tried to remove the faces to get rid of that section instead of push pull, but it opens up alot of geometry:)
my goal is to get rid of those two ribs so i have a flat and opened box.
You need a totally different approach. If you’re only interested in getting rid of the dividers in the box, erase the edges and heal the holes.in the bottom. Push/Pull is not the tool you are looking for.
There’s the area in the center where the apparent inside bottom of the box was pushed through the exterior bottom face. And because of what you’ve drawn it would be difficult to sort out the angled inside wall.
Better to start with the wall without the notch…
The color change is just the normal shading that SketchUp does to show that the model is 3D. If you are having difficulty telling the difference between that shading and the back face color, I would suggest changing the back face color to something you can more easily identify. I’m sure you’ve seen the green I use for back faces in my default style.
yes, i have seen that green. im going to do that now. thats a good idea.
and for your other question. yes those dividers and circular items need to be there. but they were not the same dividers as from the notches being cut out that i wanted removed before. these ones are placed further back:)
My idea was to make at least the empty box, then make each part and union it together.
Unless you set “use sun for shading” the light source is at the camera. As you orbit the model, each face’s brightness varies with the face’s angle to the light source. This effect can make it hard to distinguish between a reversed face and a dark shaded front face. Many of us set a garish color for back surfaces to make reversed faces stand out better.
I made the center cone as just a revolve, used clf arch centerfinder, then made the ribs and unioned everything together:) oh, and i made my reversed faces green so i can see them haha. thanks for that awesome tip.
there is one error in the pic, the ribs are 0.25 inches to high haha
