Quando utilizo a opção Importar do SketchUp em dwg ,automaticamente exclui tudo que tenho na minha área de trabalho (minhas plantas, blocos e até o componente Steve), e não dá para colocar nenhum componente depois. Como faço para resolver isso?
Translation courtesy of Google:
“When I use the Import option from SketchUp in dwg, it automatically deletes everything I have on my desktop (my plans, blocks and even the Steve component), and you can’t place any components later. How do I resolve this?”
How are you importing the .dwg file? According to your profile you are using SketchUp 2017 Free (web) which doesn’t exist. Perhaps you mean SketchUp 2017 Make? Or SketchUp Free? neither of those two has the ability to import .dwg files.
Are the objects in your file being deleted or is the file you are importing at such a large scale that you can’t see them?
Estou usando o SketchUp Pro 2017.
Os arquivos que estão na minha área de trabalho antes da importação é que está sendo excluído.
E o arquivo que estou importando não está em uma escala grande.
Please correct your profile. That information helps us help you.
Deleted from your desktop? Or deleted from the SketchUp model space?
What are the units set to in the Import options?
How about sharing your SketchUp file and the .dwg file so we can see what you are working with?
