I tried to import a “.dwg” file in SketchUp 2019 (I have to use this version for compatibility with the OpenStudio SketchUp Plugin).
The problem is that I can’t see the right drawing, but only a strange preview.
Here’s the window which appears after import:
and this is the drawing I see, and it’s not correct:
Do you know which could be the cause?
I attach here the “.dwg” file too:
Disegno.dwg (198.3 KB)
Clean your DWG file before you import it
or clean your SKP model after import.
Thanks for your help!
I’m a newbie so, after googling, I tried to use the “purge” command in Autocad, and the CleanUp³ SketchUp Plugin, but with no success.
Maybe are you able to clean this file?
In SketchUp, right-click on imported component and Edit. Select all edges you don’t need and Erase them. Then move the plans near origin.
I solved by editing the DWG file directly in Autocad.
Thank you.
