Importing from AutoCad into SketchUp 2023
Hi,
I would really appreciate some help I’m having some issues trying to import a model from Autocad LT into SketchUp.
I just keep being met with the same error message.
I’ve also linked the Autocad file.
Thanks
20240801_PMO_Local Centre Demonstration Project (Block 9)33333333.dwg (444.4 KB)
that’s not an error message. that’s the normal message telling you the file has been imported and some elements were ignored.
your file imports, but most of the plan is 74 000 km from the origin
and there are lines here and there super far as well.
after moving the plan 74000 km and deleting stuff, your plan is fine.
Sans titre.skp (355.3 KB)
I don’t know who did the dwg, but they could also clean it in autocad
hello,
it means what it means, your drawing is millions of km away from origin.
select it in autocad and move it to the origin
Ah okay thank you so much!!!
Thank you!
Sorry, if my any change you have the autocad model that you cleaned up I would i really appreciate it!
I haven’t cleaned the dwg file. I directly imported and moved it in sketchup, you can see it in my previous message
