Problem with import of .dxf files in Pro 2017 trial-Version
Hi,
I’m using Pro 2016 and now wanted to find out if the 2017 import / export of dwg/dxf is better as promised.
However I can not open the .dxf files. It works fine in the 2015 Version but not in the 2017 Trial-Version.
The error Message is: Teigha Error: (28) = (Invalid Index)
Thanks for Help
Hi Stefan, would you mind sharing your .dxf with me? email me at trent@sketchup.com
I am not seeing the error on my end.
Thanks
Trent
can you open the DXF with the free ‘Teigha Viewer’?
which version of DXF (open with text editor and see in header: $ACADVER AC10##) and where does it come from?
I can open it with Sketchup 2015 -
Header says:
HEADER
999
Auftrag: ‘P:\2016\16F-Erbach, Egginger Straße\lp 500 neu\lp 500’
999
Erzeugt mit GG-DXF
999
Versionsnummer 7.0a (3403)
999
Installationsdatei: ‘C:\PROGRA~2\GEOgraf\INSTALL\GG-ACAD.ins’
999
Modus AutoCAD
999
NULLPOS x=0.000000 y=0.000000 DIM2=0 SCHRAFFMODE=0 OTYP=0
9
$ACADVER
1
AC1018
999
Mit freundlichen Grüßen aus Ulm
Stefan Fenster
SEGETIS GmbH
Marktplatz 20
89073 Ulm
Tel.: 0731 96868 13
Fax: 0731 96868 25
mobil: 0176 99090 776
mailto:stefan.fenster@segetis.de
Sitz der Gesellschaft: Franziskusweg 44,89079 Ulm
Geschäftsführer: Bau -Ing. Lothar Fenster, Stefan Fenster
Handelsregister: HRB 726716
Gerichtsstand: 89073 Ulm
Steuernummer: 88004/29598
= ACAD v2004/2005/2006 which shouldn’t be a problem.
Does it open in the Teigha Viewer?
Yes it opens with the Teigha Viewer, of course - because it also opens with
sketchup 2015
the recent Teigha Viewer does probably use a more recent Teigha lib than SU version 2015, therfore no valid deduction.
Try if saving with the Teigha Viewer down to the DWG v2000 format works.
btw, can you remove your email signature.
Hi Stefan, thank you for the file. There was an update to the the Teigha Library that is causing the issue. We correct parties are aware of the issue and are working on the fix.
Thanks for your help on this.
Trent
