Hello. I have problem with ma sketchup 2013. I install it on my new laptopo And I have two problems. First: when I start drawing on somethinh, I ca’t see lines. They are under model . Second _ when I want to rpint into high quality, it won’t prnt all lines. please help!!! I had no problems on my old laptop, I checked everyting. Only one difference is, that on olda one I had one layer, now I have three…
Sounds like an OpenGL problem, change some settings in the OpenGL preferences in SU and see if it helps.
I tried. but I don’t know, whta should I do? I switch off open GL, nothing. Now I have dell alienware, with gtx 880M graphics.
You should try to uncheck this and restart SU…
I did it. but still I have problems. sometimes it’s drawing great but sometimes I can’t see lines. And stiil is problem with printing ![]()
are you drawing on 3 different layers?
I draw on one layer, but others two are problems. I tried to delete them, but nothing cahnged. Still I can’t see what I’m drawing, and prints are problems …
Attach the model so we can look at it. Or at least post an image.
this is file. NOw I can draw on it, but I have problem with print. zmiany.skp (559.0 KB)
ok I know much more now
It’s about settings my graphic card. maybe someone is using Nvidia on laptop to help? but still have one problem. When I’m on “perspective” I can draw on the surface with no problem. in other ways - lines while I’m drawing are hidden under model… ![]()
