Problem toolbar sketchup
Good morning.
I have a big problem with SketchUp with the VRay plugin.
SketchUp 2018 + VRay 3.06.03
PC: Win 10/Envy GTX 1060/CPU Ryzen 16 Core AMD
With Sketchup just installed all right.
Installing VRay: The toolbars do not paste where I want and the SketchUp panels return to the default position.
I can fix the toolbars and panels only when I turn on the PC, I do nothing. I start Sketchup and fix the toolbars and panels.
I close Sketchup and paste where I want it.
Also the management of the extensions does not work. Example I can not close vray (when working with several heavy models is very convenient to disable VRay).
Do you have any other negative feedback?
Have you found a solution?.
Thank you.
Marco.
si .
il PC era formattato e ho fatto la prima installazione come amministratore.
il forum di Chaos Group dice che sono a conoscenza di questo problema , ma che dipende da sketchup e di presentare il problema in Trimble. sinceramente questo problema l ho verificato su due miei Computer.
Saro’ un caso unico al mondo da studiare … hahhaahha
good morning.
I installed right-click sketchup and chose RUN AS ADMINISTRATOR.
I also installed Vray with the right button and RUN AS ADMINISTRATOR.
Chaos Group repeats that the problem is Sketchup.
I wanted to know if you were aware of it:
to fix the toolbar I noticed that if I turn on the PC and do not do any operations, I open the sketchup, I place the toolbar
and I customize the sketchup panels, close the program and reopen it, the toolbars maintain the position.
if instead I open sketchup, I use it and during the work I move the toolbar, close the program and reopen it, the toolbar does not maintain the position.
I also tried to save the Template file, but it does not change anything.
maybe you can and do a pach to solve the problem, or solve it with an update of SK2018.
with SK 2017 I had no problem.
I regularly purchase each have the new version of Sketchup. I really hope you solve the problem.
See you soon.
Marco.
Change the toolbar and make a save and exit SketchUp (Quit)
(Watch the time)
Check the timestamp of the json files:
On Win:
PrivatePreferences.json is saved to C:\Users\[user name]\AppData\Local\SketchUp\SketchUp 2018\SketchUp
SharedPreferences.json is saved to C:\Users\[user name]\AppData\Roaming\SketchUp\SketchUp 2018\SketchUp
Maybe it has to do with write permission for these locations and a very strict antivirus software setting , preventing write actions.
good evening.
I thank you for your suggestions.
I deleted the two files from the NOD32 antivirus scan.
there has been a great improvement.
now the toolbar maintains the position.
the problem that I did not delete is to create a new sketchup panel (example: materials panel) and find it open to the new working session.
I still have to set the panels in the first few seconds of turning on the PC, otherwise I can not change anymore.
now that I can move the toolbar it’s really much better to work.
I noticed that the file “privatepreferences” and “SharedPreferences” change the writing time only when I start sketchup and not at closing (I do not know if this is normal)
however, I noticed that the “SharedPreferences” file has a DAT file near it that updated the writing when the sketchup was closed.
I hope they are useful information for you.
thanks for your patience.
Marco.
