Problem opening files imported from Metashape
Good morning, I’m having problems opening files imported from Metashape, such as “obj” , “fbx”. I use the Skimp plugin, at the minimum setting for the number of faces it opens, but when I try to open it in a better quality, the “Blug Splat” error appears. I use Windows 11 and Nvidea RTX 4060. Could anyone help me?
Do you know how many edges and faces the model you are trying to import has?
What is the purpose of importing a high poly model into SketchUp?
Friend, not actually how many edges. I’m a photovoltaic designer and I process drone images in metashape, I generate the OBJ or FBX file and I’ve always been able to open them through the Skimp plugin. I recently changed my computer and it came with this Nvidea RTX 4060. From that moment on, I’ve been having blug splat problems
Then check if you have installed the latest version of drivers from the Nvidia website.
I found the number of faces: 436414
I am using the latest version of the driver
Did you check the Nvidia website or is that what Windows wrote/showed you?
This topic was automatically closed after 186 days. New replies are no longer allowed.
