Hi, I’m making a picture frame with a painting. I create a box (for the painting), then offset the outer face, then extruded that face to make a picture frame.
I’m having problems mapping textures onto the picture itself. I’ve attached the pictures, It’s the model on the left (2 boxes). When I import as texture, and map it only to the inside surface, it looks like it didn’t map.
I did a test box, and was able to map it w/o issues. Model in the center.
Then I created a box with an outset/offset face, and it would map the painting area (box with a plane). Model in the right.
When I go to XRAY mode, then the map shows up on the inside surface, but not in the area where it should be.
Can anyone explain what’s going on? I remember the method on the left model used to work in 2015 and 2014. Is this a bug? Or it’s because of some programs they rewrote? What’s the best method to make this? Thanks for your help.
