I would like to carry and use Sketchup Make with me on a USB pen drive. Unfortunately if the Sketchup Make folder is copied to a USB pen drive and I attempt to run it on another computer from there it runs Sketchup PRO instead (which in turn complains it doesn’t have a valid license).
How can I have a portable version of Sketchup Make?
To clarify, there is not a version of SketchUp which will run from a USB device. You must have SketchUp installed on the local computer you’re using, which will then have the necessary paths and registry entries for the software to run. Even the latest version of Make will not meet this need.
In all likelihood this isn’t a feature which we’ll ever address as SketchUp is very resource dependent and jumping from a computer with an integrated, non-accelerated video card to a different computer with a high end video card is going to radically change how the software operates. We need to know all of that stuff up front to offer the best experience.
Unity3D and Blender work fine from a USB pen drive on different computers regardless of whether or not the computers have integrated video cards or high end video cards. I’m sure these software packages are resource dependent as well.
Still, I understand that if the Sketchup Make software was not designed to detect the environment it operates in at run time (rather than at install time) there’s not much that can be done.
Sometimes it is more important to have access to the program and data files, than only being able to run this program on super fast computers. We understand that by using more than one computer, the performance may not be equal on all machines; I prefer to be able to work, even if it is slow.
I often must work at the customers site. If the license does not allow me to install on any computer (such as Treepad), then having a portable version can determine whether the tool (no matter how good) can be used.
