Please help, i’ve lost everything in my sketchup file. i can no longer look at anything in the file not even the grids… what happened?
If you post an image of your model statistics, then we can see if it’s still there. Sometimes leader text causes a similar error, but the good news is if you can select your model except the bad text, then you can copy it to a new file. My preferred method is to position the camera at the origin, then box select everything by using the look around tool. Copy paste to a new file and presto, it should be back to normal.
lol, worked great thanks so much!
Awesome! That’s what I like to hear. Good job.
Thank you so much!!! <3
