My file is corrupt and I can no longer save it. I have tried to save it in older versions, but that did not work. I also tried exporting the content into a new file. Even bit by bit, and it still does not work? Does anyone have tips for what I can do here?
Does the file name have some strange characters? Have you tried purging unused stuff from the file? Did you use components from the 3D Warehouse? If so, have you tried examining them individually to see if there’s any potential problems? Did you use any unusual textures? Have you tried removing textures to see if that changes anything?
Unfortunately it seems to be a very rare thing when a corrupted file can be recovered so if you still have it open on your computer,looking for suspect components and/or materials is probably your best bet.
If you start a new model and save it, does it save? If it does, can you Copy and Paste in Place chunks of the old file, and then save the new file again?
It worked for me. They come into Layout as SketchUp models. If you right-click on them and “Open with SketchUp” you’ll get the objects that you never actually saved in SketchUp.
Thanks for checking, and awesome that you reduced the size. Can you put the model you saved back in the gdrive folder? I have 77gb available on the disk, so it can not be that.
