PLEASE HELP! Failed to Open Document
I cant Seem to Open my file it show Failed to open document, this is the first time it happened to me
Here is the file bedroomm 1 & 3.skp - Google Drive
I couldn’t open it, maybe @colin could help you.
Nearly half of the file is filled with zeros. Look to see if you have an SKB file with the same name in the same folder. You can change the name of that file so that it is also .skp, and see if it opens.
I have tried opening that File too, and it has the same problem.
bedroomm 1 & 3.skb - Google Drive here is the file
Yes, it is also half filled with zeros. I don’t know what would cause that.
all I know is that I saved my file then put the computer to sleep, but while the computer was on sleep someone unplugged the computer and when I opened the pc the file is already doing that and when i click recover file its also saying the same thing. maybe the file has been corrupted.
guess I have to remodel everything, Thank you very much for your help.
Your forum profile says you are using the Free Plan. This would be the web based version. There should be a file saved in your Trimble Connect storage.
