This is a house roof and on the left side I’ve used the pencil tool to erase the edge of the triangle and separate the “soffit”. You can see the full roof is still together and I can extrude this. However, when I use the pencil tool to do the same thing on the right side, it disconnects the roof lines from the bottom of the triangle and causes the push/pull to become hollow.
I think I got lucky on the left side… would anyone be able to explain how I can reproduce this so I’m basically cutting out the soffit and leaving the roof frame entact?
Thank you!
