SU & LO 2019 Pro Classic
Win10 Pro
Adobe Acrobat XI v 11.0.23
When exporting from LO to PDF, a random diagonal line appears only in the PDF output. See image sequence below. Any ideas what might be causing the unwanted line?
Thanks Dave. I thought something was wrong with my SU model…knowing this is a bug will now allow me to stop spending time trying to figure out the problem. Appreciate your very prompt reply. Regards. Goda
Not a great option but one thing you could do to get around it is to draw a rectangle in LO to cover over the diagonal. Give it white fill but turn off stroke. Again, not ideal but it’s a quick and dirty fix that could keep you going at least until the issue gets sorted.
Quite welcome. I would suggest making a layer above the layer with the viewports but below your dimension layer for any of these rectangles. That will help you keep them separate.
