OpenCutList edge banding
Can someone help me according Open Cut List edge banding? I want my edge bandings be represented in different color on cutting diagram, I mean 2mm Abs be one color and 1mm a different color. In this panel I have 2 edges of 2mm and 2 of 1mm, on the cutting diagram the edges are blue can I make edges of 2mm be pink and those edges of 1mm be red?
i don’t see any preference or configuration options for setting the colors on hovering - you could put in a feature request to see if its an option to put this into a user configurable setting. my guess is it’s a style sheet (css) which handles the hovering colors.
Hi @mihaidascalescu ,
It not planed.
But this data could be fully read from following part list or better, from Labels.
But yes without changing color.
EDGEBANDING EXPORT ISSUE
Hi, wondering if anyone has any experience with exporting complete DXF sheet cutting pattens. (including edging subtraction & boring)
I am producing a cabinet in OCL, containing both sheet material and edge banding, when exporting cut pattern all drilling data (boing holes) disappears from svg/dxf files. when edge banding feature removed all boring data is visible on exported files again.
Can anyone help with this export problem?
what formula you used to print the edge thumbnails in labels
could this formula used in the cutting diagram also
There’s no formula for “thumbnail”. but you can choose one of the four fieldnames to display a thumbnail in Labels.
Else, 4 variables exist to allows you to extract edge material data (name, std_thickness, …) for each edge. These variables are available in cutting diagrams too.
List of variable properties (Link to the documention) :
