OpenCutList not showing angles on cut diagram
Hello,
Relatively new to Sketchup and am trying to use OpenCutList to create a cutting diagram. I can get the cut diagrams to generate but I have some dimensional lumber pieces that have angle cuts that are not showing on the cut diagram. They are just showing as straight cuts. How do I get these to show correctly? Specifically the ‘BackSideFrame’ components in the attached model. I assume it is something I am doing something wrong with the axis’? I have attached the file. Any help would be much appreciated. Thank you!!
Arcade Cabinet (OCL Version).skp (395.7 KB)
It only reports the shapes of the bounding boxes, not the shapes of the parts themselves.
ahh ok thank you, much appreciated!!
Working with only the rectangular outlines is both part of the purpose of all cutlist programs and also a shortcoming that would be extremely difficult and potentially useless to overcome.
The purpose of a cutlist is to let you know how much material you need to purchase, and most also have a layout feature that shows where you are supposed to cut each piece from the stock. But it is geared toward assessing the minimum requred raw stock, hence doesn’t take into account anything beyond bulk rectangular shape.
The shortcoming is that is cutlists don’t take into account the ways you could nest parts to get more out of the same boards. In your example, if two boards have cuts at the same angle, you may be able to fit them end-to-end against each other overlapping the points. Similarly, two curved pieces might be able to fit side-by-side across a board tighter than their bounding boxes allow.
But even more important, no cutlist program is able to account for the flaws and features of the stock. You can’t tell it where there is a knot or a check, or how the color and figure run in a board. In everything except un-figured sheetgoods or painted wood, those are aspects that affect how you will cut your parts in the real world . Unless you have the luxury of picking from a much larger stock to find ideally matched boards, you always have to allow extra in what you buy. The cutlist totals are just a starting point.
what you are asking for is True shape nesting. opencutlist doesn’t do that. Their are other paid softwares that take in actual dxf files and do true shape nesting.
