Hi DaveR thanks for the quick response. I have uploaded a screenshot so you can see what I mean.
I am trying to upload the sketchup file but for some reason my is 20Mb and is too big.
I would suggest turning off Length snapping in Model Info>Units. That can’t be helping you. And although you might not want to dimension past the decimal, setting Precision higher will make it possible to see those little errors if you create them.
As for the cross section error in OpenCutList, I can’t really help on that. I don’t use that extension for cut lists and prefer CutList 4.1. It may have something to do with the dimensions of the parts.
This is not realy an error. This message inform you that the readed section 94.0 x 43.6mm is not defined in your material standard sections.
Here it more a drawing mistake. Because if you mesure the part it doesn’t have 44.0mm thickness but 43.6mm.
Else, if the dimension is correct, just hit the “+” button to and the current section to your material definitions. And the warning but will disappear !
