I have a project I need to work on NOW, so I set everything up in December using a trial version.
I imported circa 50 in number e57 files and converted them to a RWP file. The e57 files were exported by a laser scanning company using reCap.
Everything was working great so I purchased the software (Sketchup Studio) following the trial. Despite having the Scan essentials plugin, when I open the RWP file that I created in December, it is only displaying the first e57 file, so only part of the RWP. All cropping has been deleted (I had several set up) and it is very clear to me that only one file is being displayed.
I am using G Drive, but I don’t feel this is the issue and all the paths are the same.
I tried downloading the e57 files onto my desktop and create a new rwp file from scratch. Quite annoying as this is quite a long process but i am now desperate. The frustrating thing is I can no longer select multiple e57 files, just one at a time.
If you do File → Import from the SketchUp menu you can select and import only one file.
If you use File Open from the Scan Essentials toolbar, you can do a multi-selection.
Hi Anne Marie,
RWI and RWP just needs to be at the same location, next to each other (if they have not been renamed in any way). Ans also needs to be on a local drive, not on a remote location.
