One question more about dimensions
Hi everybody.
Sorry for bothering you all again with silly questions about dimensions.
For the measurements in red I had to draw a line, take the measurement and then delete the line.
is it normal or there is a simpler way?
solid2.skp (31.8 KB)
Thanks in advance.
If you’re going to place those dimensions where you did, you need some sort of intersections or other points to anchor the dimensions to. A crossing guideline is a good way.
Thank you so much for taking time to answer my doubts :wink:
Do note that if you alter the geometry, the dimension will not change accordingly, as it is not actually anchored to the edge…
Good catch, Ian. There are ways around it. :wink:
A hidden line?
or divide the lines to give you endpoints…
john
thank you guys.
where is the hidden lĂ­ne you mentioned?
isn’t it the expected behavior?
You don’t need any extra (hidden) line.
Both edges do have two endpoints that can serve as anchor points for desired dimension.
They also have one midpoint each. So that also will do.
Create the dimension in the top plane of your object. Then rotate the dimension 90 degrees to stand up.
You can either temporarily change the drawing axes (vertical/along the edges) or constrain rotation to the slanted side face. The dimension rotates about a virtual line perpendicular to that face and through its anchor point (the first clicked point with the dimension tool). A nice one identical to the one you showed is by using both midpoints.
The dimension will be associated to the geometry to follow changes.
I need it shows 5 as size, so I don’t know what endpoints you mean, I guess I could use midpoints, yeah, but I have to rotate it afterwards.
Use (for example) both midpoints and you’ll get 5.000000mm in plane as one of three options, the one that is along the edges of both midpoints.
thank you.
Rotate the yellow marked dimension 90 degrees
Rotated to 5.000000, measured accross
p.s. 5.000000mm in plane when you first redraw the axes, one along/parallel to the two edges.
The result after rotation will be the same.
