I’m using Sketchup free on the web (early February 2024 version). I want to use the Dimensions tool to indicate the distance between two lines.
I click the first line, then drag to the second. The measurement is exactly correct, but… I can’t find a way to “stick” the end onto the second line. See video below
I have tried double-clicking, command-, contro-l, option-, and shift-clicking and none of them work. What other information can I provide? Thanks.
Expanding on what @Box showed, linear dimensions only anchor to points, not to edges or faces. But if the dimension offset line runs along an edge it is invisible.
