I imported a photo, photo matched it with the green, red and blue lines, then drew some elements on it, but, I can’t paint them. I tried opening styles, etc. but I can’t get the sliders to appear to adjust the transparency.
What am I doing wrong?
G
G
Inmenu Window > Styles > Edit >modeling Settings (last icon, blue) > (no secondary selection pane displayed) at the bottom of the first pane you find 'Match Photo. With Foreground Photo enabled you should be able to slide the slider to 100%. Can’t you?
It would be very easy to give you an exact answer if we could see the SKP file. Otherwise it’s just guessing.
But before you can adjust transparency you’ll need to paint the existing faces first while in the ‘Match Photo’ scene. when in this scene, right click (on a face) and select ‘Project Photo’. Otherewise there’ll be no texture to adjust.
ok so I found the sliders, but I still can’t paint within the photo area. I tried sliding them up and down but no joy. I tried to upload the file but is says it’s too big. G
I don’t understand. I import a photo of a building. I use the match photo function to align the perspective. I click done. Next I want to draw a roof on it. So I draw the roof with the line tool. Now I want to paint the roof. Why can’t I paint the roof?
G
[quote=“gerretw, post:6, topic:25467”]
… So I draw the roof with the line tool. Now I want to paint the roof. Why can’t I paint the roof?
[/quote] Are you sure the roof geometry drawn is ok? does the roof have a face?
Aklso you may not see the painted texture (if the roof face is there) in ‘Match Photo’ scene. Adjust the sliders, disable ‘Foreground’ to actually see the roof texture or orbit away from ‘Match Photo’ scene.
I just checked and had no problem painting the roof with aditional texture.
Note that even with 100% transparency you can’t see textures in the photo match view - you need to actually tic the box to turn it off. (caught me out a few times)
That’s why I mentioned to orbit away from ‘Match Photo’ scene.
This was the answer. Unchecking the box. Then I could paint on the surfaces I drew and it looked normal.
Next question!
I can never seem to use the eyedropper to pick up a color from a photo. In this case I wanted to paint the object the same color as part of the match photo. But I can’t.
How does one do that?
G
Simple answer - use third-party software. Either to generate a small sample or identify the colour values.
If you want to use SU:
Done.
