I use Twilight Render V2. How do I render a smooth sphere? I tried increasing faces and tried the antialiasing render mode, but to no avail. The material is stainless steel.
Have you smoothed it in SU with soften edges ?
@whiterabbitdesigncompany Yes.
Yes! I figured it out.
It’s in the advanced settings. You have to select weld vertices to enable the hard edge angle box. It does the same thing as SketchUp’s soften/smooth selection box where you specify the amount of smoothing with degrees.
+Mirror material for added effect
