Offset sections
Hi
Can we able to make offset section
I am looking for this for the sectional elevation of the Kitchen area, where the base unit and loft unit are same depth and wall unit depth inserted in. when i cut, the base unit and loft unit frames are visible and not the wall unit. When i move further the wall unit, the loft frames are not visible
You can’t create jogged sections if that’s what you’re asking. But, if you have already made your wall unit, base unit, loft unit into different groups, you can put a section plane inside each group and have three different active section planes at the same time.
Thanks
