I have several window openings at different heights on one wall. Is it possible to do multiple section planes on one wall so all openings are shown on LayOut?
Probably the easiest way to manage this is a couple or three scenes with different active section cuts stacked in LO. Otherwise you would have to individually group walls or sections of walls and add section cuts inside those groups.
Here’s a quickie example. Three horizontal section cuts with a different one active for each of three scenes. Those scenes are used in three viewports which I stacked in LO. Another possible option would be to rotate the section cut so it pass through all of the windows at once which is shown at the lower left.
Brilliant as always! Thanks again, DaveR!
